difference between b16's
Old Sep 6, 2007 | 11:21 AM
jcektyper's Avatar
Default difference between b16's
What is the main differences in b16a and b16b bottom ends? Besides compression, weight in the crank and rods. Are the journals the same size? Seals and those sort of things?
Old Sep 6, 2007 | 07:13 PM
Kyoh's Avatar
Default Re: difference between b16's (jcektyper)
I don't know anything about journals or seals but I do know that the B16B has a much taller deck height than a B16A. That's why you can't run Type-R rods in a B16A.
Modified by Kyoh at 6:38 PM 9/7/2007
Old Sep 6, 2007 | 07:40 PM
89s1's Avatar
Default Re: difference between b16's (Kyoh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoh &raquo;</TD></TR><TR><TD CLASS="quote">I don't know anything.</TD></TR></TABLE>
You CAN run type R pistons, just not the rods...
I'm not going to stick my foot in my mouth and try to answer this one, as i've never had both apart, only 1.
Old Sep 6, 2007 | 11:56 PM
Kyoh's Avatar
Default Re: difference between b16's (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">
You CAN run type R pistons, just not the rods...</TD></TR></TABLE>
Regardless, does change the fact that the deck heights are different. Which is why you can't run the rods, so so sorry.
Old Sep 7, 2007 | 10:41 AM
89s1's Avatar
ummm, my post is all correct info, and yours is only 50% correct info.... so i guess it DOES matter.
Old Sep 7, 2007 | 01:50 PM
Kyoh's Avatar
Hey dude, DON'T BE A DICK!!!
OP: http://www.raceseek.com/honda_specs.htm
This chart will tell you all the differences between the motors. Remember when reading it that a B16B is just a destroked B18c5.
Old Sep 7, 2007 | 03:34 PM
89s1's Avatar
I'm just stating facts, if I had never shown up here the Op would be misguided by your false information.
The very least you could do is edit your post to contain acurate information guy.(I'll stay away from the name calling)
Old Sep 7, 2007 | 09:49 PM
doood's Avatar
been there done that
basically, a b16b shares it's block with b18c's. b16 deck heights are a few mm shorter.
chuisek9
Apr 15, 2008 06:08 PM
Bsixteen_CRX
33
Nov 26, 2007 07:42 PM
Bsixteen_CRX
Sep 30, 2007 08:10 PM
EK9 BEEZLER
Feb 17, 2006 11:10 PM
sirb18a
Jul 29, 2003 05:58 PM
