Diagnosing Damaged LMA's
Old Dec 29, 2005 | 11:33 AM
theEGkid's Avatar
Default Diagnosing Damaged LMA's
hey all any ideas:
1.) valves are set to .007/.008 they are set very well
I ran through them again today making sure a larger
size could not fit, yet the proper size is snug.
2.) the timing belt tension is proper, the deflection is
the size of a 10mm wrench opening.
3.) VTEC is intermittant
4.) Oil pressure never throws a light, oil level is
4+ qt directly after shutoff.
5.) cams are set to dead 2,2 on my gears and the
valves were adjusted here.
6.) timing is at 16BTDC
7.) idles perfectly, no stumbling, no hesitation when
revved, good transient response to motor
8.) sound is present at idle and more so after say 2500-3800
It dissapears after 3800rpm
throttle does not change behavior
10.) I have Stock gsr cams and stock valvetrain
I think I may have destroyed the Lost motion assembilies.
Can anyone advise here?
Ive checked everythign and am left clueless
Old Dec 29, 2005 | 12:32 PM
Scott_Tucker's Avatar
Default Re: Diagnosing Damaged LMA's (theEGkid)
Did you check the lash hot or cold?
Old Dec 29, 2005 | 10:42 PM
chadmasterc's Avatar
Take the lma's out of the head. compress them with your fingers, if they stick/hesitate when they are let go then they are bad. It should be a smooth motion when you let the pressure off.
Old Dec 31, 2005 | 12:54 PM
theEGkid's Avatar
Well i check all the lms's and there all fine. Changed the waterpump and everything also. Still hearing the noise. ive come to the conclusion thats it bottom end relatied
ivtecnfg2
Apr 17, 2024 07:34 PM
aaron_ex
Oct 3, 2009 03:27 AM
mr_magoo
Aug 23, 2008 12:41 AM
an2ny888
10
Apr 14, 2006 04:36 AM
hatchinprogress
Jan 13, 2006 04:34 AM
