destroyed b-series oil pump
Old Nov 7, 2009 | 12:51 AM
!markos's Avatar
Icon3 destroyed b-series oil pump
hi,
i thought i'd share it with others, as this is the first time i've ever seen a brand new oil pump shredding itself into pieces.. the pump was new, it had 1800 miles on it, it was correctly installed, nothing wrong with it, the oil pressure was there, everything was fine. suddenly, at around 8000rpm (and also @14psi of boost), it just stopped working. this is what we saw after opening it:
the gears are totally fu**ed...
has anyone ever seen anything like that happen to a new pump???
Old Nov 7, 2009 | 05:06 AM
kyden's Avatar
Default Re: destroyed b-series oil pump
what crank pulley are you running?
Old Nov 7, 2009 | 07:45 AM
!markos's Avatar
pct n1. everything in the rotating assembly is balanced, including the pulley.
Old Nov 8, 2009 | 04:57 AM
KWayRacing's Avatar
Was that an OEM oil pump?
Old Nov 8, 2009 | 05:07 AM
shoemaker617's Avatar
Was the pump stock?modified?(by endyne,etc.) That pct n1 crank pulley was probably what caused that, you should have used the stock crank pulley that came with the crank.
Old Nov 8, 2009 | 05:11 AM
KWayRacing's Avatar
^ agree That pct offers no dampening effect.
Old Nov 8, 2009 | 08:27 AM
!markos's Avatar
100% stock oem oil pump. no modifications.
how come there are lots of engines running pulleys with no absorbers (pct, unorthodox) and they're ok?
Old Nov 8, 2009 | 09:15 AM
D-Rob's Avatar
Some are luckier than others.
No dampening on the crank pulley means the pump takes the brunt of the harmonics.
- Derek
Old Nov 8, 2009 | 09:32 AM
SoTexDC2's Avatar
If the rotating assembly was balanced properly, I'd bet on a defective oil pump.
Old Nov 8, 2009 | 10:21 AM
Garage 808 Hatch's Avatar
I've seen 5 broken brand new oem pumps. all happened while running non dampened OEM pulleys. 1 N1, 2 with OBD-0 LS pulleys, 2 with aftermarket aluminum pulleys. Switching to dampned pulleys solved this. And all 5 were balanced properly
Old Nov 8, 2009 | 10:55 AM
SoTexDC2's Avatar
If harmonics caused the pump failure, I would expect more carnage though. Especially at 8000 RPM's.
I agree, you should always use a dampened pulley.
Old Nov 8, 2009 | 11:39 AM
!markos's Avatar
thanks for all the info guys!
time to switch to a dampened pulley. i'll get circuit worx oil pump gears just in case....
Old Nov 9, 2009 | 11:10 PM
daymkimchee's Avatar
make sure your clearances between our oil pump and crank are right
Old Nov 9, 2009 | 11:35 PM
BlakeJ53's Avatar
I was just about to say that! Check out the evanstuning egine build youtube videos he will tell you the clearances!
Old Nov 9, 2009 | 11:42 PM
hondaapi's Avatar
Interesting thread!
What kind of damped pulley do most people use?
Old Nov 10, 2009 | 03:23 PM
Originally Posted by hondaapi
Interesting thread!
STICK with OEM or fluid damper
Old Nov 10, 2009 | 03:24 PM
Yea he can explain it more detailed
Old Nov 11, 2009 | 09:46 AM
Blown90hatcH's Avatar
The clearances between the gear and the housing are pretty tight that normally the gear fails and does exactly what the OP gear looks like. I would hang my loot on the crank pully killing that too.
Old Nov 11, 2009 | 09:55 AM
REEMB18C1's Avatar
? was your motor line bored by any chance
CRX T-Si's Avatar
Oh man the images of a blown oil pump brings back so much bad memories.
It happened to me and I had a under drive pully on the crank well sure enough the harmonics destroyed the pump.
After that I never use anything other then the Honda crank pullies, right now I am rocking a stock B20 crank pully. It's much lighter then the LS, GsR or ITR ones cause the center parts is hollow but the B20 pully will overdrive your accessories which is why I got it.
Old Nov 11, 2009 | 12:41 PM
!markos's Avatar
yes it was. we'll check the pump/crank clearance as soon as the new pump arrives. we haven't measured it during the first assembly.
now we will.
Old Nov 11, 2009 | 01:31 PM
Golden Eagle's Avatar
i agree i have seen this many times. you need a damped pulley
Mr. Future
Nov 22, 2015 07:46 PM
URNVS
Dec 8, 2004 08:50 AM
Trooper
Oct 28, 2003 01:12 PM
ALLMOTORJ
May 24, 2003 08:07 PM
PROFILES2000
Feb 25, 2002 01:17 PM
