Depinning connector help
I was able to replace my entire A/C rad fan harness instead of tracing wires and finding out why the original one was spliced. The replacement I got is missing one connector. Im pretty sure that I can move the connector over Im just not sure how
Are there any tutorials on this that someone can point me to?
I need this.. to go to this....
get a precision screwdriver, like a 1/16" or something, and you stick it down into where the pin is, and there is a tab that you pull and then you can slide it out of the plug. you see the square holes in the pin? thats where it locks in. so you slide the screwdriver in betweent he pin and the clip, freeing the pin, and then you can pull it out from the back. it will slide easy though, don't pull and break the wire if its not free
93egboosted
Mar 18, 2009 07:27 PM
