Deck Height of B18a1 Vs. b16a2, height of b16 and b18 head
Old Dec 25, 2005 | 09:51 PM
JDM00SI's Avatar
Default Deck Height of B18a1 Vs. b16a2, height of b16 and b18 head
Sup,.
So i own a 2000 si, and im currently reading of horror stories about people not being able to close thier hood on certain engine set ups.
Well Damn it, i havea b18a1 block and b18gsr head that is going into my 2000 si. im using hasport motor mounts that are designed for this application, although i not yet have the engine mount brackets. The brackets im talking about connect the block to the engine mounts, which brackets should i be using in order to make this mount properly, i dont want to cut anyt of hte webbing unless its very necessary.
What is the deck height of the b18a1? b16a2?
Are all heads hte same height?
Input Please!
Old Dec 25, 2005 | 09:52 PM
JDM00SI's Avatar
Default Re: Deck Height of B18a1 Vs. b16a2, height of b16 and b18 head (JDM00SI)
quick bump because i cant stop thinking of a horror story like this, and i dont want one of those mustang style hoods, haha
bump
Old Dec 26, 2005 | 05:23 AM
1700anddroping's Avatar
http://www.raceseek.com/honda_specs.htm
search next time
Old Dec 26, 2005 | 03:44 PM
raffiT78's Avatar
i dont see any reason why you have to use those mounts nor cut anything else. You can use all oem parts, and even if you use any A/M mounts the only time you would have to cut open your hood is when your block has a deck plate.
(760)doogie
Sep 5, 2008 01:23 PM
JDM00SI
Dec 27, 2005 11:01 PM
JDM00SI
Dec 26, 2005 07:57 PM
importjunkie
Mar 30, 2005 12:12 AM
rdawg000
Dec 6, 2004 05:26 PM
