Dart blocks
Old Oct 24, 2002 | 09:37 PM
  #26
texan's Avatar
Default Re: Dart blocks (StorminMatt)
Not to mention the enlarged water jackets, the closed deck, and the ductile sleeves. And for the record Dart has 2 blocks, the standard B18 with a 212mm deck and the B20+ with the 226mm deck height. Assuming B18C1 standard piston compression height, the math works out to a 1.74:1 r/s ratio on the B20+ with the GSR's 87.2mm stroke, or a 1.6:1 r/s ratio with the 95mm stroke. Displacement with their optional 84.5mm bore and a 95mm stroke would be 2.13L, and you'd have virtually identical geometry to the B18C.
Old Oct 24, 2002 | 09:54 PM
  #27
rotten's Avatar
Default Re: Dart blocks (MSchu)
They are actually near the same price as the Honda units... I seem to remember getting a quote of about $2000.
Old Oct 26, 2002 | 07:18 PM
  #28
Zeus's Avatar
Default Re: Dart blocks (texan)
Tom quoted me around $5200 for a 2.13L tall deck Dart short block a while back... family life put a stop to that purchase for me... at least this year...
Old Oct 27, 2002 | 06:11 AM
  #29
B20A5T's Avatar
Default Re: Dart blocks (tzsir)
Raise the deck heigth too much though and you run into Timing Belt length issues. That's all I have to add.... I like what Texan said.
Dustin
Old Oct 27, 2002 | 11:29 AM
  #30
jetli6969's Avatar
New User
Default Re: Dart blocks (CheezeFrog)
i bought a b20 block for 850 bux, had it sleeved at Ge for 850 shipped both waysCoulda done the exact same thing with a B18 block, but for 600 dollars cheaper
WE bought the b20 from a yard and since it was local, boosted it stck, cracked a sleeve. Then opted for Ge sleeves. If we knew it from the start, we would have gotten a b18a block for 200 bux.
jeremydde
Welding / Fabrication
22
Nov 6, 2006 06:22 AM
Miracle
Honda Civic (2001 - 2005)
May 10, 2006 08:16 AM
97itr86
Nov 26, 2002 11:45 AM
