Damn Oil =(
Old Mar 16, 2004 | 12:09 PM
SleepyHF's Avatar
Default Damn Oil =(
Ok i have checked EVEYTHING under the hood that would possibly make this damn oil light come on...NOTHING...so i figure its gotta be the computer can anyone help...ANYONE
Old Mar 16, 2004 | 12:15 PM
Jimmy's Avatar
Global Moderator
Hm..maybe your oil level?
When is thr last time you changed the oil?
Old Mar 16, 2004 | 12:36 PM
Chiovnidca's Avatar
Default Re: Damn Oil =( (ConfusedHF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ConfusedHF &raquo;</TD></TR><TR><TD CLASS="quote">Ok i have checked EVEYTHING under the hood that would possibly make this damn oil light come on...NOTHING...so i figure its gotta be the computer can anyone help...ANYONE </TD></TR></TABLE>
What's your oil presure?
Old Mar 16, 2004 | 01:23 PM
JimBlake's Avatar
The computer has NOTHING to do with the oil light. There's an oil pressure switch on the block, a light bulb, and some wire inbetween. There's no computer in that circuit...
Old Mar 16, 2004 | 01:37 PM
LudeyKrus's Avatar
Check you oil level.
If that's fine, check oil pressure.
If that's fine, check/replace the oil pressure switch.
If that's fine, see if you bottomed out and dented your oil pan.
Old Mar 16, 2004 | 03:42 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (LudeyKrus)
Autometer mechanical oil pressure gauge ... the "oh ****" light comes on when its too late anyway.
Old Mar 17, 2004 | 08:04 AM
hondaracing1's Avatar
Default Re: (LSVTEC 91 Civic)
yea my car is doing the exact thing as yours is.....i posted and they said that it could be the oil pump is clogged but idk if that helps you any
Old Mar 17, 2004 | 06:16 PM
radzer0's Avatar
Default Re: (hondaracing1)
the light on my car comes on when its humid outside.. the rubber boot on the sensor wire came off when i changed it and the humidity gets in it and makes the light come on... and im 100% sure on that
is it humid outside when it comes on for you?.. or is it all the time?
the light will be on solid and bright if its a real problem
sometimes if the sensor is bad it will be really dim.. also sometimes with the humidity it is dim.. u never know... oil pumps dont usualy go out tho
itzyaboyzeem03
Jul 1, 2016 04:40 PM
mtownek9
Apr 1, 2008 01:54 PM
motormike40
Aug 21, 2006 06:02 PM
toyH22
May 31, 2006 02:05 PM
siis2fast
Nov 4, 2005 04:54 PM
