d17 into eg?
Old Apr 16, 2005 | 07:45 AM
the jdmchop's Avatar
Default d17 into eg?
i plan on using a d17 out the new civic for my racemotor.
it going to go into my 94 ex
question being has anyone swaped one into a eg chassis?
this is gonna be for my race/street machine so modification to anything is cool!
has anyone turbocharged one of these motor in the newer civics?
the motor seems to be a realy good start, 1.7 , coil on plug, and what not
any info on this subject would be cool
Old Apr 16, 2005 | 02:59 PM
Kendall's Avatar
Plan on using the complete harness from the D17. I suppose you could use the EG harness, but you'd have to run a separate subharness for the ignition system (and possibly other things) and you'd absolutely positively have to run an EMS.
Wouldn't it be a lot easier to increase the displacement of a 1.6?
Old Apr 17, 2005 | 05:50 AM
Default Re: (Kendall)
i want to utilize the newest D series out there being that it probly the best D series motor out there, not just cause the dispacment fact which ill probly destroke to a 1.5 or so but it has coil on plug and other lil features that are sweet!
Old Apr 27, 2005 | 02:14 PM
Default Re: (jdmchop)
so noone has ever thought about putting honda's newest D into a better chassis?
this motor seem to be a good canidate for a race motor allready having coil on plug and all?
anyone with any info???????????????
Old Apr 27, 2005 | 03:53 PM
Kendall's Avatar
Regarding the CDI ignition, find a set of motorcycle coil packs that'll fit your Z6 and run an AEM EMS.
Old Apr 28, 2005 | 01:19 PM
its not just the cdi its the whole concept of using the lastest most up to date motor
if honda changed the design abit i bet it was for a good reason and it was probly an improvment
as for the stand alone ill most likly be running a motec for the race setup
thanks for info
bump
Old Apr 28, 2005 | 08:18 PM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">its not just the cdi its the whole concept of using the lastest most up to date motor
if honda changed the design abit i bet it was for a good reason and it was probly an improvment</TD></TR></TABLE>
Then you should reasearch these "improvements" and see if they outweigh the obstacles of putting a d17 into an eg... Don't choose a motor just because it is new...
Modified by Sam1am26 at 4:04 PM 4/30/2005
Old Apr 30, 2005 | 09:02 AM
Default Re: (Sam1am26)
good reply
has anyone actuly opened one of thesse suckers and compared them to the z6?
as in the flow charecteristics of the head ?
i resently seen a k-series opened up and was i amazed
Dann
Old May 15, 2005 | 09:14 AM
drowzysleeper's Avatar
my gf has a d17 and i can barely hang with her, i got a y8 with high com pistons and i,h,e. hers is stock and i drive a lil better i would like to know why she is so quik for being stock
Old May 17, 2005 | 12:15 PM
Default Re: (drowzysleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drowzysleeper &raquo;</TD></TR><TR><TD CLASS="quote">my gf has a d17 and i can barely hang with her, i got a y8 with high com pistons and i,h,e. hers is stock and i drive a lil better i would like to know why she is so quik for being stock</TD></TR></TABLE>
i like this reply better
Ed-
Old May 18, 2005 | 08:54 PM
03EM2's Avatar
if you do get the D17 make sure you get the D17a2 Vtec for allmotor because it has high comp. and use the tranny from it to shorter gears. If you plan on F/I go with the D17a1 block and D17a2 head for a good balance of high and low comp, but stick with the D17a2 tranny. the tranny in the d17a1 lags a lot in 2nd gear but has good topend pull though
purplerain11
Jul 3, 2012 12:51 AM
fallbacdun
Aug 10, 2009 03:18 AM
civictypr
Sep 6, 2004 07:36 PM
