d16z6 vs. d16a
Old Oct 27, 2005 | 02:52 PM
94ta_lt1's Avatar
Default d16z6 vs. d16a
Any difference in the two blocks? I will be replaceing the rods and pistons so if thats the only difference, thats no problem. What i'm looking to do is build a d16z6 and i have the d16a block and crank sitting around if it will work. thanks
Old Oct 28, 2005 | 12:31 PM
94ta_lt1's Avatar
Default Re: d16z6 vs. d16a (94ta_lt1)
anyone?
Old Oct 30, 2005 | 06:15 PM
94ta_lt1's Avatar
someone must know....ttt
Old Oct 31, 2005 | 06:40 AM
HiProfile's Avatar
D16a...6? I was under the assumption that all D16a blocks had the number after the 'a', since virtually all d-series in Japan were ZC's (or d15b).
If that's the case, yes it will work fine. The rods/pistons will work w/o any problem, assuming you size the bearings correctly. The only real differences are the placement of some sensors.
UniqueX707
Oct 28, 2012 09:50 AM
EGDriver93
Jan 17, 2011 02:33 PM
allturbohonda
May 7, 2004 08:53 AM
