d16a6 oil consumption/////rebuild
Old Nov 17, 2004 | 11:45 PM
panesar's Avatar
Default d16a6 oil consumption/////rebuild HELP !!!!!!!!!!!!!!!
well i just got another d16a6 to rebuild (third one). Well this particular engine consume about 1qt of oil per week (about maybe 200km). Now on the other enigne i had rebuilt i just had the cylinders punched out to about a 1.7L and then just put in niw pistons and rings (costed quite a bit) and after that they ran good.
(cheaper way) on this engine i am just thinking about honing out the cylinders to brake the glaze and install new OEM rings. And using the same pistons. Now have any of u done this? and do u think it will consume less oil than before or will it just stop burning ? All the seals valve stems seals ect.... have all been replaced, all machine work done.
From my experiance i say it should work out pretty good. But if any u have done this let me know how much it had improved.
Modified by panesar at 9:48 AM 11/19/2004
Old Nov 18, 2004 | 05:32 PM
panesar's Avatar
Default Re: d16a6 oil consumption/////rebuild (panesar)
ttt
Old Nov 19, 2004 | 07:03 PM
hellshock2182's Avatar
As long as you rehone, the rings should seat properly. That should be all you have to worry about. I would check to make sure you didn't crack a ringland before hand. It might also be a good idea to have the pistons hot tanked to clean them up before reinstall.
hope that helps
joss731
Sep 15, 2010 08:50 AM
EKB18BPR3
Jul 4, 2007 04:54 PM
92boostedgsr
Jun 23, 2007 09:47 AM
Egodestruct
Jun 11, 2004 01:55 PM
ScootinIntegra
Mar 24, 2004 10:21 PM
