d16a6 build questions.(noob)
Old May 6, 2011 | 02:20 PM
corlude's Avatar
Default d16a6 build questions.(noob)
Never done a build myself figured its about time i learned.
iv got a d16a6 that needs some love.i cant find anyone selling one in my area.
"i get the same response from everyone i call"(its rare).
the motor i currently have needs a valve and some block work.
i figured i would go with cp pistons an eagle rods.What bore/rods/crankshaft should i be looking into getting "if the crankshaft is scored"
Also if someone could point me in the rite direction on witch bearing i should replace while im in there/seals/pretty much anything else i should look into replacing.
Should i sleeve the block?if so back to the piston question"witch bore".
is there a specific head gasket i should get? (is there a better brand or is the honda oem good to go.)
is the block on a d16a6 like the prelude blocks?does it need to be sleeved or is the material its made out of strong enough to handle the honing.
should i go N/A,Turbo or stick stock?"i would like to be able to run pump gas"
Arp head bolts worth the money if i go N/A or turbo?
I'm sure i have more questions...haha haven't even touched the head yet.I'm new to civics all iv ever ran is a accord/h22a.
Iv got roughly 3k to work with.If i go turbo iv already got spool, intercooler,piping,injectors and a few other things.
xshytlipsx
May 10, 2011 10:41 AM
nggrmxn
May 24, 2008 07:21 AM
arush-civic
Honda Civic (2001 - 2005)
May 15, 2008 03:54 AM
Untouchable13
Dec 22, 2006 02:02 AM
ccivic
Mar 16, 2006 06:31 PM
