Are D16 Sumps (aka oil pans) interchangeable?
As the title says, are pressed steel sumps used on D16 engines interchangeable between different verrsions of the engine? I had a reply on this forum before that all D-Series short blocks are essentially the same.
From what I have read, some later types used alloy sumps sealed with a bead of sealant instead of a rubber gasket as with the earlier types. Could one of these be used on an earlier engine if need be?
Thanks for any replies.
EG-SIXV-TEC
May 10, 2012 06:48 PM
immalooser
Sep 25, 2009 08:05 AM
redline870
Oct 15, 2008 12:51 PM
