D15B7 MLS Headgasket question.
Old Jun 27, 2017 | 06:44 PM
Erik Shaffer's Avatar
Default D15B7 MLS Headgasket question.
Can I run a d16y8 or y7 headgasket on a d15b7?? I need MLS but need it like next day. Any help is appreciated
Old Jun 27, 2017 | 06:51 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default re: D15B7 MLS Headgasket question.
You can but it will up the compression that you will have to retard the ignition timing to avoid pinging (detonation) on high load/high rpm. The piston goes to .002" from deck height so the gasket is what provides your quench and squish zones.
The D16Z6/Y8/Y7 head gaskets are thinner than the graphite gasket that normally is on the B7. The B7 mls gasket is a thicker 4 layer mls. It's also known as the leak gasket as it was what was to replace the graphite one in the event of a HG leak. The thinner gasket reduces the quench below optimal specification and is why detonation is increased when used.
This is the OEM leak gasket (Ishino):
https://www.autopartsway.com/partdet.../pagenum1/tabs
Please note you need new head bolts if you are switching to the mls gaskets. it's part of the TSB 97-047 regarding the graphite gasket to mls gasket for 88-95 non vtec motors.
TorquelessB16
May 18, 2006 04:15 PM
1gEF-8
Jun 30, 2005 06:19 AM
AgentJam
Dec 18, 2003 08:34 AM
altoid
Feb 7, 2003 06:37 PM
