D series swap?
Old Jun 16, 2003 | 08:52 AM
rexheadb16a's Avatar
Default D series swap?
i have a 92 civic dx standard, engine code d15y7. And i was wondering if i could put in a 96 civic dx, engine code d16y7 with out many modifications. thanks
Old Jun 16, 2003 | 09:01 AM
methred_92's Avatar
Default Re: D series swap? (rexheadb16a)
yes!, basically just use the Y7 head and block with all your D15B7 boltons. (exhaust and intake manifolds, distributor, so on and so on. )
BTW, D15B7 on the 92 dx motor.
Old Jun 16, 2003 | 12:42 PM
Kamin's Avatar
why?
you are going from 102hp to 105? thats not even worth the trouble ESPICALLY because no engine makes the exact number of the factory rated HP. there is a 5hp margin for error, minimum.
thats a waste of time.
Old Jun 16, 2003 | 12:43 PM
poison's Avatar
Default Re: D series swap? (Kamin)
Yes it's possible. It will go right in, but you will need to re-use your OBD1 injectors and distributor. Along with use the factory P06 ECU to remain OBD1.
JDMTOKER
Mar 11, 2009 12:46 PM
92 CiViC HB
11
Feb 1, 2006 07:35 PM
dohdoh420
Oct 30, 2005 05:54 PM
Dancing is Forbidden
Jan 23, 2003 06:39 AM
