D Series Head Codes
Old Oct 19, 2007 | 09:49 PM
  #51
yodust's Avatar
Default Re: (95dxhatch)
hi i have a 97 dx with a hx y5 motor and i just ran the #'s on the head and i cant find them on here any where, they are p2j-6 "98" i cant find any thing on this i dont no if i put a motor that someone did a mini me to in my car? idk any help will be thankfull.
i also have a 95 si tranny to put in it, what will that do for me?
thanks.
Old Oct 22, 2007 | 01:29 PM
  #52
DS_Vtec's Avatar
Default Re: (yodust)
P08-5 93 civic del sol si d16z6
Old Dec 6, 2007 | 06:31 AM
  #53
Slow_import's Avatar
Default Re: D Series Head Codes (JohnnyLux)
good info
Old Jan 9, 2008 | 06:28 PM
  #54
D-Rizzle3's Avatar
JDM D15B(manual)-P08-3
Old Feb 17, 2008 | 12:14 PM
  #55
slowhitEJ1's Avatar
Default Re: (D-Rizzle3)
here's a wierd one.. my head said P2J-3, but is then stamped 96... as long as it's a y8, i don't care..
Old Feb 27, 2008 | 04:17 AM
  #56
MeanGreenMachine's Avatar
Default Re: (Goullish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish &raquo;</TD></TR><TR><TD CLASS="quote">How about a P08-6?</TD></TR></TABLE>
Old Mar 6, 2008 | 01:26 PM
  #57
slo_civic_1990's Avatar
Default Re: (MeanGreenMachine)
pm9-4 '90 civic std d15b1 4-sp
Old Mar 28, 2008 | 07:57 PM
  #58
ranom01's Avatar
y isnt this stickyd??, does any1 no if a po8-2 vtec head will fit onto a pm3 block??
Old Mar 31, 2008 | 02:05 AM
  #59
showbowt's Avatar
My car is a civic 99 vti a/t sedan..but my head is p2j-6 with 95 stamped on the right side..what kind of d series is that? i got the car like that already..thanks
Old Apr 30, 2008 | 02:39 PM
  #60
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: (showbowt)
Anyone ever figure out what the PM9-7 came from? The one I just got has a 93 stamp.
Old May 2, 2008 | 04:00 PM
  #61
h8tred's Avatar
Default Re: (h8tred)
Nothing? There is a severe shortage of EGs in the scrap yard, or I would look. Judging by the date code, I feel safe assuming that it's a 93-94... Meh...
Old Jan 20, 2009 | 06:00 AM
  #62
92civiccxeglove's Avatar
alright i have 2 single cam zc heads. . one head is from my buddies smashed 89 ef it had a zc swap, the head code is pm3-13 i know for sure that head was obd-o and i have another zc head my friend bought off a fellow hondarian and that code is pm3-10 im almost sure its also obd-0 because the intake mani it came with had no map sensor on the tb. . . .
Old Jan 25, 2009 | 05:12 PM
  #63
mightyjoecivic's Avatar
this is the same head code i have on a spare head, is this truly in fact a ZC head code? If so I'm gonna be livid happy! The head is a 88' and PM3-13 beside it...
Old Feb 18, 2009 | 02:31 AM
  #64
Big[V]'s Avatar
d15z7 CVT
P2J-4 99
Old Apr 3, 2009 | 09:21 PM
  #65
hondacivic4g's Avatar
I ordered a SOHC ZC, it came in tonight. Block says ZC and head says PM3-2 circle stamp next to it is 91. Not sure which motor code(D16?) this is, im trying to figure that out. An odd thing is the oil cap says "oil / Huile" on it. So far huile means mineral oil in french is all i can solidify.
Old Apr 6, 2009 | 05:43 PM
  #66
Apprently I have a D16Z1 (SOHC ZC Dual Carbed) probably from a European Honda Concerto. Hence the oil cap in French.
Old Jun 5, 2009 | 07:07 AM
  #67
codrulz's Avatar
SOHC, Vtec, ZC Stamped on block serial # 3509061
ECU – P28, OBD1
Head Code P08-1 (9/4 to right side of code)
Does anyone else have this? My jdm swap paperwork (swap done by previous owner) says it is a 1.6L Vtec, but the head codes (according to this post) indicate 1.5L. Does anyone have ZC stamped and know for sure it is a 1.5, or are all engines with ZC definitly 1.6? My headers are blocking the year code and don't really want to take them off.
I am trying to determine for sure if its a 1.6 or a 1.5 - so that way I know if it compares to D16z6 or D15b. Also, so in the future, I know what parts to get for it.
Thanks for your help.
Old Jan 22, 2010 | 12:58 PM
  #68
Avicron's Avatar
New User
1991 civic hb base model d15b1 4spd manual - head code PM9-4
Old Jan 27, 2010 | 10:34 AM
  #69
Otownking10's Avatar
what is a p08-6 9/2 1/1 2/0 I have seen some z6 heads with the p08 but none with the the -6 what does this mean
Old Feb 11, 2010 | 08:43 AM
  #70
69NOSAJ's Avatar
I have a P2J-6 with "99" on the right side it's from my 1999 EX d16y8 automatic
I ended up putting a P2J-7 with "95" on the right
and
the intake side of the -7 / 95 is different than my stock
my Edelbrock Intake Manifold had holes above each injector
the intake side of the head being different obviously causes vacumn leak because the gasket/head-side mating doesn't cover the holes above port/injector
Old Mar 29, 2010 | 09:30 PM
  #71
ramseys24's Avatar
P2H-HA-5
D15B2
91 crx hf
Old Mar 30, 2010 | 10:09 AM
  #72
JDMSOHCEG's Avatar
I want to know also!!! I have a P08-6 have no idea what it is. Somebody please help!!!
Old Sep 27, 2010 | 12:35 AM
  #73
chinoy's Avatar
P2J-6
Found on B15C2 Honda City Vtec sold in Asian Market.
Its a 4 Door Sedan. Made in 2000
Also has 00 and J stamped on it.
Old Sep 28, 2010 | 08:59 PM
  #74
barrywayne's Avatar
very useful thread.
Old Sep 30, 2010 | 05:11 PM
  #75
Gt limited(jdm approved)'s Avatar
P2A-4 head
taken from a 1997 honda integra 4 doors ZC 1600 block and P2a pistons
rated @ 120hp @ crank
