d series distributor on odb0 b16?? (need help quick)
Old Nov 18, 2002 | 12:50 PM
thecorey's Avatar
Default d series distributor on odb0 b16?? (need help quick)
i have my old d16 dist outa my crx...somone told me this can be done...by knocking off a leg on the dseries dist...it will bolt up using 2 bolts.and all the internals are teh same so it will work fine....he said he's done it....i just want a second opinion before i go hammering on my dist....i need it quickly too!! its getting dark...
Old Nov 18, 2002 | 02:41 PM
thecorey's Avatar
Default Re: d series distributor on odb0 b16?? (thekori)
it worked!! woohoo
Old Nov 18, 2002 | 03:01 PM
jdmillusion's Avatar
the d16 bolted the same pattern as an obd 0 b16? something new.
Old Nov 18, 2002 | 03:56 PM
Katman's Avatar
it worked!! woohoo
heh, let us know how long it lasts....
Old Nov 18, 2002 | 08:26 PM
thecorey's Avatar
Default Re: d series distributor on odb0 b16?? (Katman)
i had to cut a leg off....like using an integra dist...but as far as i know..the internals are the same...right?? so why wouldnt it work just as well as an integra unit??
thanks to c5allmotor for the suggestion...youre a genious!!!!! you saved me a couple of hundred..and a big headache..
Old Nov 18, 2002 | 09:15 PM
thecorey's Avatar
Default Re: d series distributor on odb0 b16?? (C5_ALLMOTOR)
why cant i rev the **** out of it?? its a damn b16...i have to rev the **** out of it to go anywhere
Old Nov 18, 2002 | 09:19 PM
sgT's Avatar
sgT
make sure the number of teeth on the internal sensors are the same.
also will depend on the ecu that you are using
Old Nov 18, 2002 | 09:55 PM
thecorey's Avatar
Default Re: d series distributor on odb0 b16?? (sgT)
well the car seems to run fine...it seems like it misses some when idling...but when i rev it up..its smooth...it dosnt cut out at all when im driving...
malo11
Oct 6, 2007 01:13 PM
civic-8442-
Jul 16, 2006 10:22 AM
out2wincrx
Jun 10, 2002 08:55 PM
