For the D-series builders...
Old Apr 17, 2007 | 08:51 AM
jdmtuner_00's Avatar
Default For the D-series builders...
I have a simple question for you guys. Do PM7 pistons fit in a D16Y7? I have heard they do, and boost up the compression pretty well. Is this true? Is there anything else i would need to get them to fit? Please let me know. Thanks!
Old Apr 17, 2007 | 09:19 AM
njn63's Avatar
Default Re: For the D-series builders... (jdmtuner_00)
They fit.
Compression calculator:
http://www.zealautowerks.com/dseries.html
Old Apr 17, 2007 | 09:31 AM
sohc_boy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmtuner_00 &raquo;</TD></TR><TR><TD CLASS="quote">I have a simple question for you guys. Do PM7 pistons fit in a D16Y7? I have heard they do, and boost up the compression pretty well. Is this true? Is there anything else i would need to get them to fit? Please let me know. Thanks!</TD></TR></TABLE>
what else are you planning on? what cam are you planning on with the y7 head or are you swapping the head for something else?
Old Apr 20, 2007 | 08:37 AM
I was going to swap the head out for a Y8 with a Gude cam.
Old Apr 23, 2007 | 04:02 AM
sohc_boy's Avatar
Default Re: (jdmtuner_00)
should be a fun combo, i'm putting together a similar combo except i'm planning on keeping the y7 head and getting a cam for it.
Old Apr 23, 2007 | 04:05 AM
D16Cowboy's Avatar
They'll fit but the piston height / combustion chamber volume with these parts will be much different. Not sure of exact specs, but if I remember right PM7 will put you somewhere above 11:1 compression; with the Y7 or Y8 head it may be even higher.
Old Apr 23, 2007 | 10:07 AM
Aquafina's Avatar
Default Re: For the D-series builders... (D16Cowboy)
Use the Z6 head in the calc. Z6 and Y7 share chambers.
SiB16A
11
Apr 10, 2007 05:09 PM
tobe1424
Feb 25, 2006 03:38 PM
TodaCivic
Jun 8, 2004 12:38 PM
wpgcivic
Dec 18, 2003 07:04 PM
euclidEH3
11
Dec 5, 2001 02:34 PM
