CX bottom EX head need info
Old Apr 20, 2002 | 11:29 PM
Chappie's Avatar
Default CX bottom EX head need info
I'm getting a 92 civic hatch CX, and I have a SOHC Vtec head that i could put on the car. I was wondering if anyone has done this so i could find out what i would need to do to get this up and running.
Old Apr 20, 2002 | 11:51 PM
ion_four's Avatar
Default Re: CX bottom EX head need info (Chappie)
I believe the CX is 8-valve, right? If so, the recesses in your pistons (if any) might be weird. If not, then you just need the ecu, or an rpm switch to turn on the vtec solenoid, but it's not as good, because it could run lean.
Old Apr 20, 2002 | 11:52 PM
egghead's Avatar
same thing as a ls/b20-vtec. But you will need to switch out the pistons. The cx has an 8 valve motor with only two valve reliefs per piston. the vtec head has 4 valves per. I've heard that ZC pistons put d15-vtecs at a "good" compression. Might want to invest in a ex/si tranny too.
Old Apr 20, 2002 | 11:54 PM
Chappie's Avatar
Default Re: CX bottom EX head need info (ion_four)
I'll have to check on the valves. Is the anything that has to be done as far as getting extra oil to the head. I thought that i have heard things about non vtec vtec swaps sometimes starving for oil.
Old Apr 20, 2002 | 11:56 PM
Chappie's Avatar
I already have an si tranny on it. if nothing else we were going to try putting the ex intake manifold on the cx, and also put the exhaust manifold on it
Old Apr 22, 2002 | 04:53 PM
Chappie's Avatar
I found out that the cx bottom end and the dx bottmom end are the same part numbers at honda. so it should work. does anyone know what head gasket to use, and any other parts that i'll need?
T-78RX7
26
Sep 4, 2012 04:10 PM
nocturnal EG
34
Jul 9, 2004 10:50 AM
drewbie*
10
Jun 12, 2004 04:54 AM
SleepinCX
Sep 5, 2003 04:30 PM
1sick4door
Mar 7, 2002 08:19 PM
