CV Joint question
Old Jul 5, 2002 | 11:35 AM
nixadm's Avatar
Default CV Joint question
Yesterday I changed my CV Joints, Brake Pad & plugs. It all works fine except when I am on the gas it shakes a little bit, not alot. Its the worst at like 60 when im in 2nd. It does not shake at all when Im not in gear & on the gas, so that rules out the tires n ****. Basicly I think I missed something when I changed the cv joints, does anyone know what could be causing this?
Old Jul 5, 2002 | 02:07 PM
speedillusion's Avatar
New User
Default Re: CV Joint question (nixadm)
i know this is sutpid, did you grease it up?
Old Jul 5, 2002 | 02:37 PM
drumsy's Avatar
New User
Torqued down your lugnuts to spec?
Old Jul 5, 2002 | 10:57 PM
bullz's Avatar
Default Re: CV Joint question (drumsy)
Check your alignment... maybe it's your Tie rods.
Old Jul 6, 2002 | 11:31 AM
Chiovnidca's Avatar
That's a good indication of a worn inner c/v joint.
Old Jul 6, 2002 | 12:10 PM
Kamin's Avatar
never fix/replace a cv joint
always replace the axle
it saves headaches (like this one) and there only 60$
Old Jul 6, 2002 | 04:37 PM
Chiovnidca's Avatar
Default Re: CV Joint question (KAMiN)
Unless you know what you are doing.
hcaulfield57
11
Feb 5, 2017 09:19 PM
Jakroy
Dec 8, 2015 01:37 PM
joelmatt89
16
Apr 4, 2009 08:12 PM
zero808
Mar 2, 2006 07:43 PM
2camsaam
Oct 6, 2003 03:10 AM
