CTR Cams better than ITR Cams???
Old May 7, 2002 | 05:17 AM
just4fun's Avatar
Default CTR Cams better than ITR Cams???
A friend talked me into getting a 98 Integra Type R. I want to build the engine up a little bit, and was wondering about non-aggressive cams. Do the CTR pistons produce more HP than the stock USDM ITR Pistons? What about the 2000/2001 USDM ITR cams? Or even the 2000/2001 JDM ITR or CTR cams? Do they product more HP than the 1998 USDM ITR cams? Thanks... SEAN
Old May 7, 2002 | 05:58 AM
EEK's Avatar
EEK
Default Re: CTR Cams better than ITR Cams??? (just4fun)
the ctr cam is 82 its bigger then itr cam....its good for first gear throughs you off the line a lot harder....my friend had a dc2 with intake exhaust ctr cam..he ran 14.8 on 17's it helps out a lot
Old May 7, 2002 | 06:04 AM
Spade's Avatar
Simple answer, not enough for you to notice.......
The CTR INTAKE is better but, the exhaust cams are the same........
Old May 7, 2002 | 06:21 AM
just4fun's Avatar
Default Re: CTR Cams better than ITR Cams??? (Spade)
Thanks for the help! How about the CTR Pistons? Are the JDM ITR Pistons / Cams any different from the USDM? Thanks again!!!
Old May 7, 2002 | 06:38 AM
EEK's Avatar
EEK
theres is no difference in cams only the ctr intake cam which is bigger, ctr is higher compression then the itr
rico suave
May 27, 2012 09:32 PM
swizz977
Jul 23, 2010 12:24 AM
b18c1sircivic
Apr 8, 2008 04:49 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
AfEn808
Nov 2, 2001 05:36 AM
