ctr cams in b16 how much power
Old Sep 18, 2001 | 05:00 AM
sohc_boy's Avatar
Default ctr cams in b16 how much power
how much power would ctr cams give a b16a from a 2000 civic si? anyone have dyno sheets? are they worth it?
Old Sep 18, 2001 | 07:52 AM
3.3.3's Avatar
Default Re: ctr cams in b16 how much power (sohc_boy)
small gains on a stock motor that hasnt been tuned. they are worth it since the profile is better than your si cams. you should only buy the CTR intake cam since the exhasut cam is identical to the ITR. dont expect 10-15hp increases.
Old Sep 19, 2001 | 07:33 AM
JDM_DOHC_SiR's Avatar
New User
ABout 6~8 hp thought out the RPM range but may be a little more with cam gears +2ish
Old Sep 20, 2001 | 08:35 AM
eg6ajk's Avatar
Default Re: ctr cams in b16 how much power (JDM_DOHC_SiR)
check the archive (integra DA or Si coupe) http://www.importtuner.com/
without cam gears only 3.0hp, with cam gears (tuned) +5.hp more (8hp total), makes much more if you have the first gen cams or auto cams...
Performance Chart
HP Level HP+ TQ Level TQ+
B Baseline Power 138.9 * 102.2 *
1 Civic Type R Throttle Body 140.3 1.4 102.7 0.5
2 Integra Type R Camshafts 143.3 3.0 103.5 0.8
3 Hayame Adjustable Gears 148.4 5.1 106.0 2.5
F Final Power 148.4 9.5 106.0 3.8
1SlowSi
42
Apr 21, 2005 07:19 AM
slipstreamsi
Jul 6, 2004 03:57 PM
anekin007
Jun 25, 2004 01:54 PM
Quiks66
Oct 31, 2003 05:40 PM
sihatchyvtec
Aug 26, 2003 10:33 AM
