CTR BUILD questions
Old Jun 21, 2007 | 04:36 PM
Horseofcourse's Avatar
Default CTR BUILD questions
Is it possible to run A GSR BLOCK, B16A Head, CTR PISTONS, with LS Rods?
On zealautowerkz compression calculator it says with GSR rods it will have piston to deck height of .006 which is dam close but with b16 it will drop teh compression to low. But with the LS rods it seems like an almost perfect match.
Are all B-series rods the same Besides LS?
Im New and i searched for all you old rat bastards
Old Jun 22, 2007 | 11:37 AM
civicstar's Avatar
Default Re: CTR BUILD questions (Horseofcourse)
u need the ls crank
Old Jun 23, 2007 | 02:20 AM
sheekdude's Avatar
I think they are all similar in length besides the LS rod, but the type r is a bit different in strength and weight.
Old Jun 23, 2007 | 12:33 PM
doood's Avatar
been there done that
Default Re: CTR BUILD questions (sheekdude)
b18c1/5 = 137.90
b18a/b/b20 = 137.00
b16a = 134.00
b16b = 142.30
b17 = 132.00
all in mm
Old Jun 23, 2007 | 06:16 PM
Doood your awesome thanks
Old Jun 23, 2007 | 06:17 PM
doood's Avatar
Default Re: (Horseofcourse)
actually that info is on the zeal calculator. i was just pointing it out.
fv8s
17
Jul 9, 2010 12:25 PM
Horseofcourse
Jun 21, 2007 08:21 PM
Coolest Dude Ever
Jun 8, 2007 02:39 PM
egchan
May 24, 2004 09:23 AM
spettinger
Feb 5, 2003 03:25 PM
