CRX Wiring
Old Feb 16, 2004 | 08:24 AM
simplestyles's Avatar
Default CRX Wiring
I have this problem with my crx. I lost power to my ecu and the factory book says that with the problem engine light on and constant check the wiring for the TPS MAP and the PA(Baro Pressure). Do any of you have any experience with this? The ecu is not fried, I swapped with known good ecu. Connection at the strut tower is good for the +to the three sensors. Any information would help.
Thanks for the help
Paul
Old Feb 16, 2004 | 12:01 PM
Perfectionist's Avatar
Default Re: CRX Wiring (simplestyles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplestyles &raquo;</TD></TR><TR><TD CLASS="quote">I have this problem with my crx. I lost power to my ecu ...
Paul</TD></TR></TABLE>
Was it a temporary power loss to the ECU (fuse/battery disconnect?) or is it still dead? Your post isn't clear.
If it's still dead, check the fuse and wiring providing the +12 to the ECU first.
Old Feb 16, 2004 | 02:52 PM
Fobtions's Avatar
Default Re: CRX Wiring (Perfectionist)
check all your ground connections, especially the one that is bolted to the water neck in the back.
Old Feb 18, 2004 | 07:59 PM
Checked all fuses and for twelve volt power at the ecu. no power all fuses are good thanks for the feed back Ground at the thermostat is good as well
any other ideas?
hannahscrx
Oct 18, 2007 08:31 PM
Beau Gotti
May 16, 2006 06:36 PM
MrMayhem
Nov 22, 2005 07:54 PM
EKRacer
Mar 28, 2004 02:27 AM
KevronsEG
Apr 21, 2002 01:49 PM
