CRX rear LCA question
Old Jul 28, 2007 | 11:46 AM
autoxthis's Avatar
Default CRX rear LCA question
Just got my ground controls mounted on tokiko blues and when i went to install the rears I noticed the LCA would not work with the new shock mount fork.
My LCA's have a hole where the shock drops down into and a bolt runs through the lca and into the stock shock (its like threading a needle).
New shocks have fork style mount with no bushings and they are supposed to mount around the LCA. I just bought the car and now suspect the rear suspension is swapped from different year. If it helps the car is a 91' CRX HF.
MY main question is does anyone have any idea if the LCA's are stock or replaced?
Old Jul 30, 2007 | 07:21 AM
BoostdRex's Avatar
Default Re: CRX rear LCA question (autoxthis)
Those are replaced... In my experience, only the '88 has the LCA that you describe. I have owned each of every year and the '88 (maybe '89 as well but can't remember) was the one with the shock that dropped into the LCA...
Old Aug 22, 2007 | 05:50 PM
alscrx's Avatar
Default Re: CRX rear LCA question (BoostdRex)
Yes, only 88 has the ball mount rear shock. The 89-91 have the fork mounted shocks. Just get aftermarket Lower control arms. BLOX makes a set and company are selling them on here for like 85-95 shipped!! That fixes all your problems
Old Aug 23, 2007 | 11:57 AM
Garrett's Avatar
Default Re: CRX rear LCA question (alscrx)
88 civic/crx, integra type R
dans all JDM except EK had box type LCA like you have
if you had box type on you 91 , they were changed
box type are better than forks type
db8db8db8
Oct 16, 2009 04:35 PM
silver_racer
Feb 18, 2009 09:40 PM
autoxthis
Jul 28, 2007 02:38 PM
performula
Dec 13, 2002 08:27 AM
rainman
Aug 26, 2002 06:37 AM
