CRV timing belt problem HELP
Old Jul 6, 2010 | 01:25 PM
xurinox's Avatar
Default CRV timing belt problem HELP
hello!!! heres what happend and what i did! honda crv 2000 with 147000k bone stock,i understand its a B20 , timing belt broke crusing around 70mph , replased the timing belt,put the time to the white line and the 2 marks on the "up" ,also replaced the tentioner,water pump,spark plugs and the 3 belts... torque to spects,did a valve adjustment,also a comprecion test 175,170,170,170....with those numbers i dont think a valve was bend!!!
problem: engine starts quick withouth no problem but there its no power, i press the gas and it takes forever to build RPM's..... please i need help!!!
Old Jul 6, 2010 | 05:23 PM
perseverance's Avatar
Default Re: CRV timing belt problem HELP
sounds like you're off a tooth
Old Jul 7, 2010 | 08:33 AM
xurinox's Avatar
Ill double check!
Lokisdope
Oct 7, 2007 07:48 PM
ammccrea
Oct 25, 2005 11:23 AM
hitvtecgetloud09
Mar 16, 2004 12:32 AM
