crower or skunk2 camshafts?
Old Sep 1, 2002 | 10:51 PM
FastFoot's Avatar
Default crower or skunk2 camshafts?
im havin a hard time on deciding on which cam to buy. im choosin between crower 403 and the skunk stage 2 cams. i did my research and both of them seem to be good. which one is better? im gonna upgrade all my valvetrain..gonna be for street/strip..mostly strip tho..opinions please. thanx
Old Sep 2, 2002 | 08:22 AM
non-VTEC's Avatar
Default Re: crower or skunk2 camshafts? (FastFoot)
if you went with crower i would go for the 63402's. the 403's alot of people have trouble tuning and require so much more engine work to make good power with. plus the power is all in the high-end.....
Old Sep 2, 2002 | 09:57 AM
The_Head's Avatar
Is ths a VTEC or Non-VTEC motor you are gettting cams for?
Old Sep 2, 2002 | 10:10 AM
FastFoot's Avatar
Default Re: crower or skunk2 camshafts? (xThexHeadx)
ls/vtec with ctr pistons.
Old Sep 3, 2002 | 09:53 AM
builthatch's Avatar
MiG-21 superfan
skunk2 stageIII is better than crower3, they both require alot of tuning and hardware/software support to make proper power...
Old Sep 3, 2002 | 11:21 AM
The_Head's Avatar
Well, I run the Crower 402's right now. They require the Crower valvetrain too, and some sort of aftermarket programming (VAFC, etc.) for the ECU. I ran with a stock ECU for a week before I got the Hondata installed. I got 10 whp just by installing them, and I expect another 10 whp could be had by adjusting the cam gear timing. These cams move the VTEC engagement point to ~6000, its pretty cool when the motor engages VTEC, the cams add a lot of top end. I suspect they take away some bottom end, because my motor doesnt really come alive until after 3500 rpm...
Old Sep 3, 2002 | 06:11 PM
FastFoot's Avatar
what stage hondata did u get?
Old Sep 3, 2002 | 06:52 PM
The_Head's Avatar
3b
Old Sep 4, 2002 | 08:41 PM
B00ST2nR's Avatar
Skunk2 Skunk2 Skunk2!!!
Old Sep 4, 2002 | 09:25 PM
F1Spec's Avatar
Default Re: crower or skunk2 camshafts? (Skunk2nR)
jun?
Old Sep 4, 2002 | 09:37 PM
B00ST2nR's Avatar
Default Re: crower or skunk2 camshafts? (fwu)
jun?
yes? (Jun is my name by the way). Are you calling my name or are you refering to Jun Cams?
Old Sep 4, 2002 | 10:09 PM
FastFoot's Avatar
would anyone like to explain why skunk2 stage 2 over the crowers? wat makes em better? again this is for a fully built ls vtec with a ported head..
Old Sep 4, 2002 | 10:25 PM
MikeSarr_GSR's Avatar
this sounds like one for ImportReview (Jeff) to answer.
Old Sep 5, 2002 | 08:33 AM
builthatch's Avatar
MiG-21 superfan
compare the numbers...
Skunkworks Stage III INTAKE LIFT. 0.504, DURATION 270, EX. 0.465, 279
Crower3 0.472, 260, EX. 0.466, 250
The Skunk piece is just more aggresive!
Old Sep 5, 2002 | 11:46 AM
W.Zero's Avatar
ive seen two gsr with the same basic bolt on but one with crower and the other with skunk and the skunk gsr won. but it also depends on driver!
flac0
Jun 15, 2009 08:04 AM
tagperformance
Aug 15, 2006 09:10 AM
VTECcnIT
Oct 29, 2005 04:48 PM
stRodda
Aug 3, 2003 01:41 AM
