crank sensor problems
Old Jan 19, 2009 | 03:22 PM
KAZANOVA15's Avatar
Icon6 crank sensor problems
wats up guys i have a 98 civic ex.just did a 96 ls swap,but im having a problem with the wiring. mostly every thing pluged in exept my crank sensor. the plug out of my ex harness has 3pin wire and my crank sensor has two,what can i do.is there a web site were i can find a wiring diagram
Old Jan 19, 2009 | 04:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: crank sensor problems
Are you talking about the "Crankshaft Speed Fluctuation Sensor", a 3wire on the civic engine and a 2 wire on the LS engine
98Civic...
White to white/red-------- CKFM pin on PCM , [ECU/ECM/PCM]
Light blue to blue/orange--CKFP pin on PCM
Black to brown/black------- chassis ground
96LS...
White to red/white---------CKFM pin on ECM [ECU/ECM/PCM]
Blue to blue/red------------CKFP pin on ECM
So looks like the only diff. is the LS engines CSFS does not have the chassis ground and a diff. in color of the CKFP lead and the Civics computer is called a "Powertrain Control Module" and the Integra computer is called an "Engine Control Module". 94
Old Jan 21, 2009 | 01:40 PM
KAZANOVA15's Avatar
Icon3 Re: crank sensor problems
so just cut the plug of and butt conect the wires to the ls plug and just ground the black one.or can i just feed the black wire back into the harness.sorry im not that smart when it comes to wiring.and is there annything else i should know about this wiring
Old Jan 21, 2009 | 04:10 PM
fcm's Avatar
fcm
Old Fart
Connect the two that are needed and see what happens, the ground is just a ground, the diff. may be that the LS sensor grounds through chassis and the Civic did not. 94
Wink1100
Feb 11, 2010 10:36 AM
EfSedanLove
Jan 18, 2007 08:43 AM
civickid03
Jul 25, 2006 03:02 PM
92HB_HB
May 15, 2003 02:57 PM
