cracked sleeves?
Old Sep 7, 2010 | 08:05 AM
thegatekeeper14's Avatar
Default cracked sleeves?
how can i figure out if my sleeves are craked on my f22 with out replacing the head?
story goes i was burning coolant so then i pulled the head did the gasket and milled the head. now, it still burn coolant so i pulled all the hoses off the intake manifold thinking one of them was mixxed up but that wasnt the case either. any ideas?
Old Sep 7, 2010 | 02:50 PM
srmofo's Avatar
Default Re: cracked sleeves?
Leak down test.
or a block tester, but you can get false positives with any chemical tester if used improperly.
Neither of those will give you 100% that it is the sleeves and not just a head gasket, but if everything else is in known good shape, then its a pretty safe assumption.
Did you not look at the cylinders at all when you had the head off?
Old Sep 7, 2010 | 10:18 PM
97ek-t's Avatar
you sure it still burning coolant and not just the coolant that is left in the exhaust? i did a swap once on a car with a blown head gasket and thier was so much coolant in the exhaust that it smoked 30 min after with a new motor
thechad888
Dec 1, 2013 08:56 AM
Rayzorx
May 2, 2011 11:27 AM
prelude1911
Jun 5, 2007 07:55 AM
hb_guy
Oct 29, 2005 06:12 PM
