Crack on injector tip?
Old Jan 12, 2003 | 08:52 AM
CivicSoul's Avatar
Default Crack on injector tip?
I need advice! I got these and didn't notice the crack on the black cap that directs spray. The thing that surrounds the needle. Actually there are two cracks down both sides and it spins around unlike the other 3. This might be a dumb question but my buddy said that it doesn't matter because one of his injectors had the same thing and didn't effect his car at all. I know he dosen't know all so I am turning to you. My fear is that is will blow off and get caught somewhere it shouldn't like melt to the plug, jam in the piston or stuck in a valve. Do you think it is safe to install? Will the injector still work properly? Any advice will be appriciated. If you say no go then I need to find a new one. The other three are fine. Thanks for all of your help
Old Sep 26, 2006 | 04:41 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Default Re: Crack on injector tip? (CivicSoul)
bump
Old Sep 27, 2006 | 07:21 AM
Kiniku Chunks!!!
Guest
Posts: n/a
I would definitely replace it, that's how it started on my boys acura integra. A little crack that developed into a big problem. He kept leaking gas and his **** started detonating.
So advice, replace that **** and don't gamble, unless you are a gambling man.
Good luck
Old Sep 27, 2006 | 07:47 AM
slomofo's Avatar
GDD Member
The little black plastic tips don't direct the spray, it won't hurt your engine.
racingant
Oct 9, 2005 07:26 AM
Fallen86
Jun 9, 2005 06:57 PM
ls-r civic
20
Sep 29, 2004 03:10 PM
10seceg
Jan 1, 2004 02:46 PM
