Could it be the starter? or something else?
Old Mar 31, 2003 | 07:01 PM
Bbasso's Avatar
Default Could it be the starter? or something else?
Here is the deal: the power is constant in the thick wire and the small wire gets power when the key is in the start position, So why doesn't my car start?
Old Mar 31, 2003 | 07:42 PM
Alexander's Avatar
Default Re: Could it be the starter? or something else? (Bbasso)
whatever it is I hope you get it fixed soon good luck
Old Mar 31, 2003 | 10:02 PM
RangerDan's Avatar
Default Re: Could it be the starter? or something else? (AVD23)
does it turn over and not start. or does it not turn over at all?
Old Apr 1, 2003 | 03:18 AM
Bbasso's Avatar
Default Re: Could it be the starter? or something else? (RangerDan)
When I turn the key it does nothing, no sounds no clicking no nothing.
Old Apr 1, 2003 | 10:24 AM
JimBlake's Avatar
If the small wire gets power when you try to start, and the wires are actually fastened properly to the starter, not corroded... Then your starter is bad.
Sometimes you can get it to start by having someone rap on the starter with a screwdriver while you try to start. If that works, its certainly a bad starter.
Old Apr 1, 2003 | 10:39 AM
Quik Chris's Avatar
Default Re: Could it be the starter? or something else? (JimBlake)
Is the starter getting 12V? Make sure the ground didn't pop off? Also be sure that the ground from the Tranny to the body of the car is connected too.
[Modified by Quik Chris, 12:40 PM 4/1/2003]
Old Apr 1, 2003 | 01:49 PM
Bbasso's Avatar
Any other thoughts?
thanks
Old Apr 1, 2003 | 04:07 PM
TurboDelSol's Avatar
it could be the battery...even if all your lights work..the battery might not have enough cold cranking amps.. sometimes jumping it wont work because the battery is really dead..u just have to replace it
Old Apr 1, 2003 | 05:26 PM
PnX-R's Avatar
If I remember correctly....
Turn the key and nothing happens means that there is a problem in the First Starting Circuit. It stems from the Battery to the Starter Solenoid, not the Starter itself.
If you turned the key and you heard a Click, then the problem is in the Second Starting Circuit. It stems from the B Terminal of the Starter Solenoid, through the Starter and to Ground..
What I would do is take a look at the Battery cables and posts and see if they're corroded or loose. Next I'd check for corroded or loose Starter Solenoid wires. Sometimes the corrosion can be underneath the plastic casing of the cables/wires..
Back to the First Starting Circuit. Turn the key and no Click, might be an Open Pull In Coil.. Wish I could tell you how to test it.. But if you do look up the procedure, let me tell you one thing.. You can always test a Coil to be faulty/bad, but you can't test it to see if it's good. This is because there could a Hot to Hot Short in it.. I don't want to get into too much detail though..
That's just what I've learned. But hey, I could be wrong.. Good luck dude..
Old Apr 1, 2003 | 11:04 PM
Quik Chris's Avatar
Default Re: Could it be the starter? or something else? (PnX-R)
Here's the picutre of the ground you were asking about. When I dropped this motor in, I coupletely forgot to attach it, and it didn't do **** except spark on the ground from the valve cover to the radiator support.
here ya go:
Old Apr 2, 2003 | 01:39 PM
Bbasso's Avatar
Default Re: Could it be the starter? or something else? (Quik Chris)
Ok I see your picture and I did attach that wire, thanks for the effort in helping me.
Old Apr 3, 2003 | 07:44 AM
tpr's Avatar
tpr
Default Re: Could it be the starter? or something else? (PIMPASSBEOTCH)
Last resort before buying a strater use a jumper wire and directly connect 12 VDC to the small terminal. If the strater turns over then its in the 12 volt signal from the switch, start tracing.
Old Apr 3, 2003 | 07:49 AM
MikeMAN's Avatar
if ur car is manual try to bumpstart it...
mike
Old Apr 3, 2003 | 10:41 AM
Bbasso's Avatar
Default Re: Could it be the starter? or something else? (MikeMAN)
Well I have a new starter in my hands and I'm going to install it now.
Wish me luck
Old Apr 6, 2003 | 12:02 PM
Bbasso's Avatar
I almost forgot to tell ya all that the starter was the whole problem, put it in and turned the key and it came to life.
Thanks!
Jack Murphy
Jun 21, 2017 06:23 PM
gooblinn258
Dec 16, 2013 08:23 AM
slowassBubble
May 15, 2011 07:50 AM
crx1856
Aug 20, 2003 10:24 PM
