Coolant Temp Sensor
Old May 5, 2002 | 06:19 PM
1hottEG6's Avatar
Default Coolant Temp Sensor
In regards to ECT sensors between d series and B series engines do they have the same resisitance or is one higher than the other....(and if so what are they appox. I know someone knows this...
Old May 5, 2002 | 07:20 PM
Jared's Avatar
Default Re: Coolant Temp Sensor (B20eg)
same resistance at every temperature. afaik, every 88-00 honda is the same
Old May 6, 2002 | 02:20 AM
tinkerbell's Avatar
Default Re: Coolant Temp Sensor (recall)
i think you may have mis-interpreted.
but anyways,
ill leave it upto you to correct...
t..
[Modified by tinkerbell, 11:20 AM 5/6/2002]
Old May 6, 2002 | 02:53 AM
recall's Avatar
Default Re: Coolant Temp Sensor (tinkerbell)
yes my mistake, i apologize
ZootownEG
Engine Machining & Assembly
Jun 5, 2019 11:44 AM
K.Quinn
Apr 29, 2007 06:07 PM
ALL MOTOR EM2
Feb 17, 2007 04:40 PM
