conntecting pipe
Old Jan 12, 2006 | 11:43 PM
sik96teg's Avatar
Default conntecting pipe
I was wondering if the connecting pipe and thermastat housing off a 96 gsr would bolt up to a type-r motor cuz i see theres diff part numbers between the 2
Old Jan 13, 2006 | 01:33 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: conntecting pipe (sik96teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik96teg &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if the connecting pipe and thermastat housing off a 96 gsr would bolt up to a type-r motor cuz i see theres diff part numbers between the 2</TD></TR></TABLE>
It may bolt up differently, but in theory you should be able to use that one fine.
Old Jan 13, 2006 | 04:29 AM
v4lu3s's Avatar
RTFM
i bet the thermo housing is diff since the 2 engiens use differnet heads.
Old Jan 13, 2006 | 05:18 AM
JimBlake's Avatar
Default Re: (v4lu3s)
Or maybe the pipe has extra hose nipples for the oil cooler...
Old Jan 13, 2006 | 06:40 AM
v4lu3s's Avatar
RTFM
good point on the oil cooler as well.
Old Jan 17, 2006 | 07:33 AM
sik96teg's Avatar
no diffs with it from the head because my head was already jdm type-r. My bottom end was gs-r and i jus got a good deal on a full type-r bottom end i picked up but i do believe there is another coolant line that comes from the connecting pipe i will have to check into that
parsapour
Apr 28, 2018 08:57 PM
raverx3m
Mar 31, 2012 11:47 PM
Luke G.
Jul 4, 2009 05:56 AM
dc4drewb
Apr 9, 2008 12:49 PM
