Concerning Skunk2 cams
Old Jan 12, 2003 | 08:09 AM
MikeSarr_GSR's Avatar
Default Concerning Skunk2 cams
Looking for anyone who has had negative experiences with this line of
cams. I have recently heard about a breakage issue with a set in an H22 (thanks for the info Natalie)
Anyone have problems with this on the stage 1 grind for the B series motor?
Are there any recorded stories concerning negative effects with running these cams? I will preform a search considering this is a new line I am curious. Now that there are a good number of sets out there, some road reports should be ready to come in. whats the word on long term usage peeps?
Old Jan 12, 2003 | 11:49 AM
sleepycivix's Avatar
Default Re: Concerning Skunk2 cams (MikeSarr_GSR)
im on 10K miles with skunk2 stage 2 cams.. love them.. no probs
Old Jan 13, 2003 | 10:39 AM
Evolsport's Avatar
Default Re: Concerning Skunk2 cams (sleepycivix)
Mike:
I have a Set of Skunk2 Cams Stage 1 I purchased a couple of years ago....and I have about 70k+ Miles on them.....I recently burnt a valve at 190k miles....and did a major overhaul....but when I checked the cams....they still look good. But I am running synthetic 10w-30 Mobil one on them so I know that helps them last long.
Old Jan 13, 2003 | 11:41 AM
Default Re: Concerning Skunk2 cams (Evolsport)
thats encouraging, glad to hear your motor is running strong with that kind of life on it... Kudos man!
Old Jan 13, 2003 | 02:53 PM
skunked's Avatar
Skunk2 Stage 1's
Old Jan 13, 2003 | 06:11 PM
EleanoR's Avatar
Default Re: Concerning Skunk2 cams (skunked)
Mike~
i am throwing in a set of Skunk2 stage 1 cams this week and will be dyno tuning cam gears, VAFC, ignition timing in the next couple of weeks. Looking to get 190+whp. I have researched these a lot and it seems that for the money they are great cams to have which is why i bought them. I am in college and on a budget!
mike
orlando, fl
mike
Old Jan 14, 2003 | 08:28 AM
Default Re: Concerning Skunk2 cams (EleanoR)
yea they are great cams... and only get better as you raise compression...
Old Jan 14, 2003 | 02:58 PM
StinkyTofu's Avatar
I've never heard anything but good things about the Skunk2 stage 1 cams. I'm considering swapping my toda b's for those cams. What would you guys recommend for 11.67:01 compression and why? Toda B's or SK2 Stage 1's?
Old Jan 14, 2003 | 04:25 PM
Default Re: Concerning Skunk2 cams (StinkyTofu)
in my mind it would be all about where in the rev band you want power. the Bs have more lift...
Toda Spec B 12 mm,duration - 255 @ 1mm 12 mm, duration - 245 @ 1mm
Skunk 2 stage1 11.58 mm, duration 252 @ 1mm 10.9 mm, duration 249 @ 1mm
on the duration side the skunks breathe more on the exhaust side... 3 deg less on the intake side but roughly the same degrees of overlap. I know the todas also manipulate the low cam lobes whereas thes skunks do not until the stage 2 cam. Skunk's low lobes are near identical to the pri and sec of the CTR/ITR I believe, making them easier to drop in and run/tune. The todas will definately take some time tuning the idle, low cam maps, etc. For 11.6:1 both cams seem to be no brainers... even stock ITR cams with that compression would scream well above 9K... the skunks from an ease of use and price factor would be my cam of choice
Old Jan 17, 2003 | 11:47 AM
Tuan's Avatar
HOw do you identify SKUNK2 cams and stages? by looking at the CAM itself?
Old Jan 17, 2003 | 01:09 PM
Default Re: Concerning Skunk2 cams (Tuan)
I have seen both the 1s and 2s side by side and you can see the 2s have larger lobes all around, main diff is the pri and sec are much larger than stock.
Old Jan 17, 2003 | 01:12 PM
ILUVTEC's Avatar
What up Mike, doin more research I see, later, Clay
Old Jan 19, 2003 | 07:58 PM
Default Re: Concerning Skunk2 cams (ILUVTEC)
ubecha... talk to ya soon bro
Old Jan 19, 2003 | 09:14 PM
NiMhist's Avatar
lol @ "I live in the Magic Kingdom with Cinderella"
Old Jan 22, 2003 | 01:18 AM
Default Re: Concerning Skunk2 cams (NiMhist)
sup john boy get those cams for the b16a? gimme a shout
panda_eh2
May 1, 2008 08:16 AM
HB1234
Dec 5, 2005 11:23 AM
crazzeboost
Oct 9, 2004 06:51 AM
1quik95gsr
Mar 19, 2003 09:35 PM
B00ST2nR
Mar 1, 2003 04:11 PM
