compression test question
Old Jun 16, 2010 | 07:45 PM
yolk's Avatar
Default compression test question
ls/vtec b18 w/gsr ported head, 1/2 mm oversized valves, 11-1/2 to 1 pistons what should the compression readings be at spark plug holes i know they are several different combinations between block decking and head gasket thickness just need somekind of guideline to go by... THANKS
Old Jun 17, 2010 | 09:20 AM
EJ1B18c's Avatar
Default Re: compression test question
I dont think the number is what you should be worried about. Its the difference between cylinders, im usually happy with anything less then 15psi.
Also compression testers will read differently.
For reference my readings are between 285psi and 300psi on 13:1 with pro2's Intake set at 0,Exhaust +4 on pro gears.
Old Jun 17, 2010 | 01:51 PM
v.ice1's Avatar
if your using stock pistons and the head isnt milled dont expect anything above 240 per cylinder considering that the block has fresh rings the compression test should be done with the car at op. temperature
Old Jun 17, 2010 | 03:03 PM
jdm602's Avatar
it all varies. dynamic compression is different then static compression.
not all gauges are the same too. so you can have one read 205 and on a diff gauge it might read 240.
Old Jun 18, 2010 | 06:05 AM
fcm's Avatar
fcm
Old Fart
Ditto all the above, be more concerned that they are all the same, [or very close]. 94
skippy33
Feb 7, 2021 05:34 PM
zoom545
Nov 22, 2005 09:04 AM
aut0tek
Mar 18, 2003 11:00 AM
