compression test for h22a
Old Dec 28, 2004 | 07:10 AM
crazi_E's Avatar
Default compression test for h22a
im going to be doing a compression test wih my friend, but i dont really kno what number should come across the screen...i heard i should get over 200 for each vavle...i want to make sure...need help!
Old Dec 28, 2004 | 07:26 AM
H22Chameleonaccord's Avatar
Default Re: compression test for h22a (crazi_E)
That's not always true. I had a all-motor h22 that hit about 190-200. I also had a low-compression motor that hit 170. As long as they are about equal across the cylinders, you should be fine. If one of the cylinders is way out compared to the others, then you could have a problem
Old Dec 28, 2004 | 11:40 AM
crazi_E's Avatar
Default Re: compression test for h22a (H22Chameleonaccord)
ok so is there at least a low number it could be at that would still make it good?...
Old Dec 31, 2004 | 04:16 AM
93H22APrelude's Avatar
i have a JDM h22a My compression was 260 all 4 cylinders on full throtle
Old Dec 31, 2004 | 04:18 AM
Default Re: compression test for h22a (93JDMPrelude)
and its stock with a intake, Greddy PE, Hi-Flow cat
Old Jan 3, 2005 | 07:58 PM
hOndafienD 04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93JDMPrelude &raquo;</TD></TR><TR><TD CLASS="quote">i have a JDM h22a My compression was 260 all 4 cylinders on full throtle </TD></TR></TABLE>
thats pretty high wouldnt you agree? i would think that 220ish would be average
Old Jan 4, 2005 | 03:49 PM
Default Re: compression test for h22a (hOndafienD 04)
higher the better
Old Jan 4, 2005 | 04:59 PM
yes i know
what pistons are you using? the type s ones? or just regular jdm's?
Old Jan 4, 2005 | 05:10 PM
Luke J's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">
thats pretty high wouldnt you agree? i would think that 220ish would be average </TD></TR></TABLE>
260 is also high from what I've seen
Old Jan 4, 2005 | 05:30 PM
well i did the test today and the gauge was broken! arg! lol but anyways i went ahead and tried anyways...the gauge would not hold the pressure...the little valve was missing...but i noticed that cylinder 1 every crank came up t about 75, while the other 3 came up to about 120.....i can start assuming but im gonna check it tomorrow with a working gauge.
Old Jan 4, 2005 | 05:40 PM
Luke J's Avatar
Default Re: (hOndafienD 04)
Yea, there is no way to get a good answer with an erratic/inoperative gauge.........
-let us know what it reads with a different gauge
Old Jan 4, 2005 | 05:44 PM
sure will...but i smeel #1 cylinder having a problem.
Luke J's Avatar
only one way to know for sure.................
Old Jan 4, 2005 | 05:45 PM
Luke J's Avatar
Default Re: (Lucky925l)
Are you referring to the car in your sig, with 230k?
Old Jan 4, 2005 | 06:06 PM
no im not....im refering to the red ek in crazi_e's sig.....it has a jdm h22 in it that sucked up some water
Old Jan 5, 2005 | 09:49 AM
ok here are the results...not happy :-(
cylinder 1: 130
cylinder 2: 210
cylinder 3: 210
cylinder 4: 180
so they one thats really fucked up is the 1st one, and i guess since 1 and 4 work together some water got into both.....time to rip apart the head.
Old Jan 5, 2005 | 02:14 PM
hybridpatient95's Avatar
bump. what should we do??
Old Jan 5, 2005 | 02:24 PM
Luke J's Avatar
Default Re: (frankenfiend 04)
Pull the head off
Old Jan 5, 2005 | 02:26 PM
and do what tho?? thats what we need to know.
Old Jan 5, 2005 | 03:28 PM
think we got a couple bad valves?
Old Jan 6, 2005 | 01:28 AM
im using stock JDM pistons
Old Jan 6, 2005 | 01:31 AM
Default Re: (93JDMPrelude)
not Type S..... 260 all 4
Old Jan 6, 2005 | 09:33 AM
damn so eveb the 210 is low correct? cuz its jdm h22a non type s.
Old Jan 6, 2005 | 01:40 PM
210 is still good
Old Jan 6, 2005 | 04:26 PM
Luke J's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">and do what tho?? thats what we need to know. </TD></TR></TABLE>
I would take the head off, inspect the head-gasket. (were you burning coolant?)
Visually inspect the head/valvetrain. Visually look at the bottom end, what does the top of the piston and cylinder wall area look like? Any signs of serious wear, dis-coloration, any metal shavings in oil? Possible pison ring or ring land issue...
