compression readings
friend and i just finished a ls/vtec swap into a crx and we checked the compression in all the cylinders. the first through the third are all at 195 psi, but the fourth is showing 120 psi. the b18b block/head was fine before the head swap..... would the cause of this low compression reading be caused from a bad valve stem seal?
your valves should be closed which means that the valve/valve seat it self would have to be leaking, the it will all leak out via the manifold. i would be looking some where else ie valve backlash, dirt under the seat not allowing it to close, worn rings etc.do the old favorite of putting a teaspoon of oil down the sparkplug hole and redo comp test. if comp goes up it's something in the rings if not then look at your valves.
nemesis25
Jan 12, 2015 04:17 PM
chickenandpickles
Aug 30, 2005 11:21 PM
