compression numbers....
Old Jan 23, 2003 | 09:48 PM
DevilSolSi's Avatar
Default compression numbers....
Hey whats up, I did a compression test on my d16z6 and it read 165 across the board. the motor has about 86k on it
it seems like most peoples numbers are usually higher than this so should I be worried?
I think my car could use a valve adjustment so could that be a reason for the numbers?
The boost is comming soon so I want to make sure everything is good before I put the turbo on.
Thanx guys....
Old Jan 23, 2003 | 09:53 PM
TEAMGENDAI's Avatar
Default Re: compression numbers.... (DevilSolSi)
165 sounds ok but do a leak down on it to be sure with that many miles it should be less then 10 % bu the car will run with way less than that.
Old Jan 23, 2003 | 09:58 PM
DevilSolSi's Avatar
Default Re: compression numbers.... (TEAMGENDAI)
yeah a leak down test is going to occur in teh near future
efking1985
Jul 26, 2010 02:13 PM
InLimbo87
Jun 22, 2004 07:54 PM
kabaroo
14
Oct 26, 2003 01:13 AM
EF8_SiR
Jul 20, 2003 10:24 PM
