Compression check 200+ across the deck. what comp is it?
Old Jun 30, 2003 | 12:08 PM
migs's Avatar
Default Compression check 200+ across the deck. what comp is it?
If I got a compression check of 205ish across the deck, what is the compression ratio approximately?
Old Jun 30, 2003 | 12:10 PM
Ivan's Avatar
senior gold member
Default Re: Compression check 200+ across the deck. what comp is it? (Migs)
I remember hearing that your compression test results have nothing to do with what compression ratio you're running. Whats the setup?
Old Jun 30, 2003 | 12:18 PM
migs's Avatar
Default Re: Compression check 200+ across the deck. what comp is it? (Ivan)
Stock B20. I just read a thread about identifying a B20. I remember getting 205ish when I first got it, but the details say I have an 8.8:1
ef_si
Jul 25, 2013 02:09 PM
Nisif
Apr 12, 2005 09:13 AM
zwalk
Jan 25, 2005 07:37 PM
