Comment on this.. Is it true?
Old Feb 14, 2003 | 10:27 AM
Nikos's Avatar
Default Comment on this.. Is it true?
Here's something I picked up from Honda-tuning
Please comment:
Interestingly, what you won't find under the hood of any of those dragsters is an H series engine. Despite apparent built-in advantages--such as a closed deck from the factory and a bigger bore and stroke--chief Holeshot wrencher Aaron Bonk tells us that the H is rarely used in drag engines. Part of the reason is the way the cylinders are lined. The sleeves in the H are much thinner, which don't allow for the flexibility in boring that one can take advantage of with a race-prepped B series engine. Because of this, the cylinder walls can't take the ultra-high boost levels found in modern front-wheel drive dragsters. Bonk points out that while an H engine can comfortably produce between 600 and 700 hp, there are B engines that are putting out close to 1000. Luckily, for our street-driven Civic, such high-horsepower concerns are irrelevant, however interesting they may be.
Old Feb 14, 2003 | 10:37 AM
bryan305's Avatar
Default Re: Comment on this.. Is it true? (2 B 4GO10)
Maybe that's why import builders won't work on them
http://importbuilders.com/nopreludes.html
Old Feb 14, 2003 | 10:39 AM
1BlackHatch's Avatar
Default Re: Comment on this.. Is it true? (bryan305)
Actually if you look on
www.importreview.com
you will find that jeff seems to respect the H22A. However, I think that they mainly specialize in B-series.
Old Feb 14, 2003 | 10:42 AM
bryan305's Avatar
Default Re: Comment on this.. Is it true? (1BlackHatch)
If it's a problem with the cylinders being weak, why wouldn't they just have them resleeved like the b series?
Old Feb 14, 2003 | 10:49 AM
mattcxb18's Avatar
only 700hp that sucks! That is what I run on my b (give or take 550whp)
Good Find
mike_chomik
Aug 11, 2013 08:47 PM
ross3974
Jan 5, 2010 08:42 AM
Nayr
Jun 15, 2007 08:20 AM
moz92
Jan 23, 2007 11:38 AM
tico
Jul 10, 2006 05:51 PM
