coilover adjustability ?
Old Feb 23, 2004 | 06:18 PM
wuclan's Avatar
Default coilover adjustability ?
just a thought about height adjustment on coilovers. If i install coilovers set the hight to what i want i then need an alignment. My question is, if i decide to change the settings for whatever reason and then put them back to their original setting later will i need an alignment again? Also, assume i make these changes within a day or two not months.
Old Feb 23, 2004 | 08:23 PM
wuclan's Avatar
Default Re: coilover adjustability ? (joeegg)
anyone?
Old Feb 23, 2004 | 08:34 PM
miguel6632's Avatar
u guessed it yes youll need an aligment but it isnt that bad ..remember chamber doest eat tires toe in or out does
Old Feb 23, 2004 | 09:48 PM
wuclan's Avatar
Default Re: (miguel6632)
thanks for answering
Old Feb 24, 2004 | 10:51 AM
suspendedHatch's Avatar
Default Re: (joeegg)
Let me see if I understand your question. You set all four coilovers to point A, mark them, then get an alignment. Then you tweak the settings to point B w/out getting an alignment. Later you put them back exactly to point A.
No you will not need another alignment.
In fact, you can have the toe adjustment marked at point A, get another alignment at point B and mark the toe adjusters with a different color,and then you'll be able to switch back and forth. A can be your street ride height and alignment, and B can be your track ride height and alignment.
Old Feb 24, 2004 | 10:59 AM
FR-MOB: ThE bEe GuY's Avatar
Default Re: (shaundrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">Let me see if I understand your question. You set all four coilovers to point A, mark them, then get an alignment. Then you tweak the settings to point B w/out getting an alignment. Later you put them back exactly to point A.
In fact, you can have the toe adjustment marked at point A, get another alignment at point B and mark the toe adjusters with a different color,and then you'll be able to switch back and forth. A can be your street ride height and alignment, and B can be your track ride height and alignment.</TD></TR></TABLE>
... thats a friggin good idea! I wish i thought of that when i had my crx Same thing if you have a camber kit, you can just mark where it is and readjust it.
Old Feb 24, 2004 | 12:07 PM
rapid_roy's Avatar
What you should do is set your height so that you get the camber setting you desire, have it aligned and never touch it again.
Cheers,
Sean
tallguy21
Suspension & Brakes
Feb 11, 2013 05:08 PM
APAem1
Suspension & Brakes
Feb 11, 2011 03:02 PM
jxhxb
Suspension & Brakes
Jan 9, 2009 10:51 AM
ek4d00r
Suspension & Brakes
May 17, 2005 03:40 PM
Volcom
Mar 3, 2002 07:10 PM
