Coil Over Suspension
Old Sep 12, 2003 | 01:11 PM
shannon's Avatar
Default Coil Over Suspension
Are Coil over kits worthed when used with stock integra shocks?
Old Sep 12, 2003 | 02:16 PM
VTEC-DA's Avatar
Default Re: Coil Over Suspension (shannon)
I dont know what "worthed" means, but coilovers will work fine with stock shocks, however, chances are the stock shocks will go out pretty quick.
Old Sep 12, 2003 | 06:10 PM
shannon's Avatar
Default Re: Coil Over Suspension (VTEC-DA)
ttt
Old Sep 13, 2003 | 07:24 AM
bartek_b's Avatar
they will be good....depending on what drop you go to.
if you go anything more then 1.5" - 2", you risk blowing them quickly
Old Sep 13, 2003 | 11:00 AM
roydogg's Avatar
Default Re: Coil Over Suspension (mugen85r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen85r &raquo;</TD></TR><TR><TD CLASS="quote">they will be good....depending on what drop you go to.
if you go anything more then 1.5" - 2", you risk blowing them quickly</TD></TR></TABLE>
And it'll be best if you find out what the spring rates are. To stiff and there goes you shocks.
Old Sep 13, 2003 | 06:56 PM
shannon's Avatar
Default Re: Coil Over Suspension (roydogg)
ttt
Old Sep 13, 2003 | 06:58 PM
shannon's Avatar
Which ones are good ones, I'm thinking of buying the ones they have on procarparts.com ,
Old Sep 13, 2003 | 08:37 PM
ion_four's Avatar
everyone raves about groundcontrol "coil-overs", but despite the fact they are eibach springs, I would call their standard ones rice. This is because the standard spring rates they offer are just about stock rates, so it's just to lower the car. You can get basically any rate you want from them, but if you just ask for coil-overs, without specifying, they will give you weak ones, or so I understand. Personally, I think springs are springs, when the rates are the same. SO, I have DropZone Coilovers (uber-ricey) but, swapped the springs for 350F/450R and it is a pretty tight ride with KYB AGX shocks. Did I mention dropzones are only $100, shipped?!
Old Sep 13, 2003 | 11:31 PM
HYREV2NR's Avatar
My R has stiffer shocks from the factory. I have Skunk coilovers & They are only a bit bumpy @ times on bad roads but, over all I likem. If you can find a set of Type R shocks to go with a decent set of coilovers youl be fine. DON'T FORGET TO GET AN ALIGNMENT!!!!!!!!!!!!!!!
Old Sep 16, 2003 | 02:18 PM
shannon's Avatar
Default Re: Coil Over Suspension (HYREV2NR)
ttt
g5r
Suspension & Brakes
Mar 17, 2007 09:49 PM
incognito E46
Suspension & Brakes
10
May 6, 2005 06:34 AM
07civicEF
Jan 3, 2005 02:20 PM
wm5holla
Apr 26, 2003 05:02 AM
-iLLuZioN-B18C1
Apr 22, 2003 08:52 PM
