Codes 6 And 7 At the Same Time
Ok well here we go I took the A/C out and the next day I get a 6 & 7 check engine code. The car now idels high and starts to overheat. Does the A/C have any thing to do with those things
Code 6= Ect sensor (engine coolant temperature)
Code 7= tps sensor (throttle position sensor)
I need any help that I can get
in the process of removing the AC did you unplug or break the 2 sensors?
is the car running funny?
if not try resetting the ECU and see if the pop up again
.brad
Feb 26, 2002 03:30 AM
