Code p1259 comes up on Integra
Old Apr 11, 2007 | 12:39 PM
ITR32's Avatar
Default Code p1259 comes up on Integra
Iam having idle problems and vtec doesnt hit. The code Iam getting is p1259 fuel metering. Does anyone know what solenoid or device would send this code. I tried to clear it and after a few minutes it comes back so I figure it needs replacing.
Old Apr 11, 2007 | 01:02 PM
NathanielH's Avatar
Default Re: Code p1259 comes up on Integra (ITR32)
Thats a code for the VTEC pressure switch, or solenoid valve circuts. not fuel metering.
Old Apr 11, 2007 | 01:06 PM
ITR32's Avatar
Default Re: Code p1259 comes up on Integra (NathanielH)
were should I look first? could the sloenoid be out
Old Apr 11, 2007 | 01:13 PM
NathanielH's Avatar
there is a problem somewhere in that system/circut(s). youll have to start diagnosing it, do you have a test light or multimeter? start by checking all connections. there could be a problem with the wiring, with the switch, with the solenoid, with the ecu, ect....youll have to diangose it to narrow it down
Old Apr 11, 2007 | 01:27 PM
ITR32's Avatar
ok thanks will start checking the wiring
Old Apr 19, 2007 | 10:36 AM
tuan...'s Avatar
ever find out this problem? i am also having this problem and my idle sucks too. Does yours drop wayyyy down? Mine does, but it has not once died.
seth01tuner
Sep 10, 2012 02:57 PM
wrxya33
Jul 6, 2007 08:16 AM
jdmbreed
Oct 18, 2006 11:31 AM
type Gendy
Aug 2, 2003 05:44 PM
boost killz
Sep 5, 2001 06:30 PM
