CODE 8 PLZ HELP
Old Feb 27, 2007 | 02:45 PM
ANONYMOUSdeecee's Avatar
Default CODE 8 PLZ HELP
I CHECKED FOR CEL CODE TODAY.....I GOT A 8......TDC......NOW I NEED TO KNO WAT IT IS AND HOW TO FIX IT......
Old Feb 27, 2007 | 05:42 PM
Mikey3000's Avatar
Default Re: CODE 8 PLZ HELP (ANONYMOUSdeecee)
its a sensor in your distributor and unfortunately its not fixable so you need a new distributor.
Old Feb 27, 2007 | 06:34 PM
Default Re: CODE 8 PLZ HELP (Mikey3000)
OH.....THANKS I'LL TRY THAT
Old Feb 27, 2007 | 08:18 PM
SHOULD THE LIGHT GO ON ONCE THE CAR STARTS OR AFTER AWHILE?????????
Old Feb 28, 2007 | 02:17 PM
Mikey3000's Avatar
i don't think the CEL comes on even while cranking if there are no codes.
Old Feb 28, 2007 | 04:27 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">i don't think the CEL comes on even while cranking if there are no codes. </TD></TR></TABLE>The CEL always comes on (bulb & ecu check) for about 2 seconds then turns itself off.
Most codes clear themselves after several driving cycles. The CEL goes out but the code remains stored in memory.
Old Feb 28, 2007 | 07:36 PM
Default Re: CODE 8 PLZ HELP (JimBlake)
i have a ls/vtec setup...b4 i hooked up the vtec i would get a CEL before i even turn the car on......so thats wat i meant.......now b4 for the CEL goes on the motor act kinda crazy....the rpms go fro 5000 to 8000 on pure idle......but after the CEL it act how it should
Old Feb 28, 2007 | 07:55 PM
sauceja's Avatar
You can just replace the housing and keep the dizzy guts. Just swap them over.
You should be able to find a housing somewhere.
Hetterley
Engine Management and Tuning
Apr 19, 2016 06:54 PM
SiR-T
Oct 6, 2007 04:06 PM
94VXLSHatchie
12
Jul 25, 2006 05:17 PM
slickboy
Oct 18, 2005 06:12 AM
92HB_HB
May 12, 2003 12:23 PM
