code 43
Old Jun 16, 2002 | 04:23 PM
chad's Avatar
Moderator
Default code 43
43=Fuel supply system circuit.
how do i fix this?
Old Jun 16, 2002 | 08:32 PM
InevitableRace's Avatar
Default Re: code 43 (Chad)
take the light bulb out
Old Jun 16, 2002 | 11:24 PM
Sonny's Avatar
25 Year Member
It could be as simple as your gas cap not being on tight enough. Check it, reset the ECU, and try gain.
Sonny
Old Jun 17, 2002 | 03:51 AM
Todd Reid's Avatar
Default Re: code 43 (Sonny)
this is usually a bad 02 sensor, in my experience.
has happened twice to me; start the car up and no light for about 2 minutes. then the check engine light comes on. if you drive for a while, then shut off the motor and start it again, does the light go out? i put a meter on my O2 sensor, and it was acting "lazy" so I replaced it. problem solved!
good luck
Todd
PS this was on a 94 OBD-I Teg motor.
ryanminer
Oct 17, 2008 08:52 AM
BABE-BOY
Jan 8, 2008 08:35 PM
solofthesouth
Apr 30, 2006 08:22 AM
vtecfiendsh
Feb 12, 2003 10:10 AM
