CODE 4 How DO I FIX THIS!!!!!!!!!!!
Old Mar 30, 2003 | 05:12 PM
Proper's Avatar
Default CODE 4 How DO I FIX THIS!!!!!!!!!!!
I know I already posted this in the CRX/EF forum but no one even looked at it and I need a speedy reply. So sorry mods for the double post. You can delete the other one if you wish.
Anyway...My car started running like **** out of nowhere this afternoon and it thew a code4=Crank position sensor. What exactly is this and how do I fix it? I took off my dizzy cap and there is all this maroonish colored dust in there. Could this be part of the problem? Thanks in Advance!!
[Modified by CamoHatch, 6:18 PM 3/30/2003]
Old Mar 30, 2003 | 05:27 PM
poison's Avatar
Default Re: CODE 4 How DO I FIX THIS!!!!!!!!!!! (CamoHatch)
Yes, that is the problem. The Crank Position Sensor is located in the dist. I would suggest replacing it and make sure the wiring is good
Old Mar 30, 2003 | 05:42 PM
Proper's Avatar
Default Re: CODE 4 How DO I FIX THIS!!!!!!!!!!! (poison)
replace the distibutor right?
Also I was told that it may be the ignitor. could that be it maybe??? Sorry I'm just trying to see if there is a less expensive alternative
edit: Thanks for the speedy reply
[Modified by CamoHatch, 6:42 PM 3/30/2003]
Old Mar 31, 2003 | 12:03 AM
7PSI CRX's Avatar
All of that orange dust is the distributor bearing on it's way out.
Remove the whole distributor and spin the bottom of the shaft by hand.
It should spin freely with the only resistance being the magnetic pickups.
Blow all of that dust out with compressed air.
Don't drive the car with a bad distributor bearing, you'll get stuck, or worse....
kirbyman
Oct 20, 2024 07:35 PM
scottso990
10
Aug 2, 2010 12:54 PM
Ukraine Train
Jul 21, 2004 12:16 PM
EKhothatch
Mar 29, 2004 05:52 AM
