code 3, what to do?
Old Oct 9, 2002 | 09:19 AM
TheOne's Avatar
Default code 3, what to do?
My car is throwing the check engine light ( code 3-map sensor), I have no idea what to do to try and fix this, can someone please help.
Old Oct 9, 2002 | 09:44 AM
sieger's Avatar
Default Re: code 3, what to do? (TheOne)
Check to make sure the MAP is plugged in. if it is reset the computer and see if the code comes back. If it comes back then you likely have a bad MAP, that's what the check engine light is telling you. Are you running boost?
Old Oct 9, 2002 | 01:17 PM
LSVTEC408's Avatar
Default Re: code 3, what to do? (sieger)
i have the same problem, what can i do to fix it, does this got do anything with my vtec controller, let me know.
Old Oct 9, 2002 | 03:54 PM
TheOne's Avatar
Default Re: code 3, what to do? (LSVTEC408)
yes I am running boost, but I have some kind of different map sensor. FYI I did have a vafc, and I took it out because I never could get the wires connected well enough to have it run without problems, would this be a result of my bad vafc install, perhaps maybe one of my ecu wires?
Old Oct 9, 2002 | 04:08 PM
sieger's Avatar
yeah
Shoalin R
May 21, 2010 01:42 PM
cjames235
May 10, 2005 12:52 PM
RaVeN
Oct 17, 2002 06:50 PM
Xsi
Sep 23, 2002 07:50 AM
crxtreme27
Aug 9, 2002 09:22 PM
