code 21
Old Jul 2, 2005 | 09:35 PM
demdem's Avatar
Default code 21
Well today I got a Spoon ecu OBD0, I took out my stock ecu and install it the first thing that happen after installing the spoon ecu the check engine light came on I drove the car and no v-tec come in. So I took back out the spoon and install back the stock ecu same problem. I install the ecu in my friend car v-tec came on find everything find with his car with both ecu. So I check the code on the ecu and I was getting a code 21 ( VTEC spool solenoid valve) Don't now what to do from here PLEASE HELP
Old Jul 3, 2005 | 05:40 AM
Suck my DX's Avatar
Default Re: code 21 (demdem)
take ur solenoid off and clean it
Old Jul 3, 2005 | 03:39 PM
demdem's Avatar
Default Re: code 21 (Suck my DX)
well thanks for the help but I have sort out the problem the connector on the harness that goes to the v-tec the wire fell out I just pop it back in and I am good to go
Old Jul 3, 2005 | 05:57 PM
theinfamouskonrad's Avatar
just solder the wires together instead if you can't get it back into that little harness.
Ef4doorwagon
Mar 11, 2015 05:59 PM
crxmex
Oct 5, 2006 01:35 PM
sytema
Mar 23, 2005 06:54 AM
RoaringTurtle
18
Aug 5, 2002 01:17 PM
EGh22aEG
Mar 18, 2002 04:18 PM
