code 17, VSS - could be due to tacho not working?
Old Sep 16, 2004 | 05:37 PM
tinkerbell's Avatar
Default code 17, VSS - could be due to tacho not working?
getting code 17 in 1990 CRX with B20VTEC.
the speedo works fine (is a bit jumpy) and i am using a LS integra mechanical VSS in the J1 tranny to provide the speedo cable drive.
the tacho is not working.
could this affect the VSS at all?
i have not checked for signal at the pin B16 of the ECU yet...
thanks for any comments or experiecnes
t..
Old Sep 16, 2004 | 05:45 PM
Propulsion's Avatar
Default Re: code 17, VSS - could be due to tacho not working? (tinkerbell)
Im having the same problem, my tach and speedometer both work fine, but still throwing the code after a few minutes of driving, especially when I decelerate in gear.
Ill paypal $10 to anyone who can solve this problem for me.
Old Sep 16, 2004 | 05:48 PM
tinkerbell's Avatar
Default Re: code 17, VSS - could be due to tacho not working? (SilverCIVIC96)
is you VSS mechanical or electronic?
what car? what OBD?
Old Sep 16, 2004 | 05:54 PM
drvfast's Avatar
I am having the same problem. I have a mechanical vss; the model car is an 88 hf with a xsi swap converted to Obd 1. Vtec is not working either.
Old Sep 16, 2004 | 06:19 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote">Im having the same problem, my tach and speedometer both work fine, but still throwing the code after a few minutes of driving, especially when I decelerate in gear.
Ill paypal $10 to anyone who can solve this problem for me. </TD></TR></TABLE>
****!, I had the same CEL while decelerating in gear problem, and it turned that I had a ton of corrosion in the connector to the VSS and it wasn't making a solid connection. This is a 95 Prelude H23 OBDI...
I got a new VSS and cleaned the connector and now no CEL and speedo works perfect
Check your connector and you may even get a temporary fix by jiggling that connector...
Old Sep 16, 2004 | 10:53 PM
Propulsion's Avatar
Default Re: code 17, VSS - could be due to tacho not working? (Hawkze_2.3)
OBD1 uses the electrical right?
I have a obd0 89 Dx w/ a b17a swap (running on obd0 pr3 ecu)
Old Sep 17, 2004 | 12:40 AM
tinkerbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 uses the electrical right?
I have a obd0 89 Dx w/ a b17a swap (running on obd0 pr3 ecu)</TD></TR></TABLE>
yep - virtually the same problem as me.
i will be checking the signal from the speedo to the ecu tomorrow - to see if it is this...
i think i have found out (through search) that the tacho wont affect the VSS at all...
Old Sep 17, 2004 | 12:02 PM
Propulsion's Avatar
ok, well let me know if you solve it, cause it's bothering the hell out of me
Old Sep 17, 2004 | 01:20 PM
honda_power69's Avatar
I have the same problem only while running my Uberdata chips...on deceleration after driving for about 5 minutes throws a code 17.
Swap in the old gay-*** Mugen clone chip and no problem. I'll be checking the VSS connector and wiring today also, I'll post what I find.
Old Sep 17, 2004 | 07:22 PM
crexer's Avatar
Default Re: (honda_power69)
silvercivic have you tried unhooking your battery and resetting your ecu? I heard something about after hooking your battery back up start the car and dont touch the gas pedal for like 5 minutes and it will reset itself this way. anyone wanna verify this?
Old Sep 19, 2004 | 06:21 PM
Propulsion's Avatar
Default Re: (crexer)
yes, Ive reset my ecu many times, didnt help...
Old Sep 20, 2004 | 02:27 AM
Slow_Em1's Avatar
get a new VSS
Old Sep 20, 2004 | 02:46 AM
tinkerbell's Avatar
Default Re: code 17, VSS - could be due to tacho not working? (Slow_Em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 &raquo;</TD></TR><TR><TD CLASS="quote">
get a new VSS</TD></TR></TABLE>
um, he said speedo is working - so the VSS should be OK.
civicSF98
10
Aug 30, 2009 05:10 PM
89hatcher
May 16, 2007 12:36 PM
dthug
Aug 17, 2006 11:29 AM
92integraVTECgsr
Oct 25, 2005 11:28 AM
89dxhunchback
Nov 3, 2003 09:18 PM
