code 15 help
Old Nov 11, 2003 | 09:00 PM
ITSTOCK's Avatar
Default code 15 help
Putting a d16a6 in a 89 crx hf and its throwing a code 15 igntion output signal. tryed swapping the hf dist on it and it still threw the code which leads me to beleive its not ignitor or coil. The car didnt throw the code with the hf motor either.
Old Nov 11, 2003 | 10:03 PM
HONDADNA's Avatar
Default Re: code 15 help (ITSTOCK)
The start singal has it's own fuse most likely under the dash fuse panel. I recommend checking that first - it may be named PGM-FI or integrated control unit.
if the fuse is okay check your wiring.
usdm_ED7
Aug 30, 2011 09:30 AM
mhewitt
Sep 16, 2010 10:03 AM
kevcha711
Feb 5, 2010 07:32 PM
0ne-Cam
14
Aug 20, 2009 06:58 PM
Gennady
Jan 28, 2002 11:32 AM
